best or badass 4x6 speakers
  • 6
oz has some good ones to. so does memphis. personally if i were you and you wanted "simple" i would get q forms for your s 10 and get a decent comp set..might cost a lil more but you wont be asking whats better than the 4 4x6's 6 months from now.
Buddy of mine had an extended cab truck that had 4X6's and he was running clarion. Sounded real nice. They had removable tweeters for better imagining. May want to check into those.
:thumbsup
Once again; you may want to consider the Kappa 4x6 plates, and the Oz audio 4x6's. Polk also has a 4x6 plate out. Their are kickpanels available for your truck, but the question is would you be comfortable with giving up some leg room, because i've tried putting in some kickpanels in my cavailer but it just wasn't comfy (gosh, that car is small). I have kappa 3.5" coaxiles and they are ok.
Would you or anybody know if its possable to fit a 4" midrange in their. You could have a pre-fabricated, or fabricate a "plate" to fit a 4" midrange (and possabily with the tweeter beside it), but i can't help you their.......
Oh` yeah; if you do get a plate or fabricate one remmember to note that the woofer's magnet sits to the side rather than in the middle like normal coaxiles (as in the mounting depth). Just thought that i pointed this out to save any possable trouble.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
599
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
910
MikeGray
Pimp Juice
MikeGray
bay Area
cwzilly
vlusardi
    Apr 27, 2024
winkychevelle
    Apr 27, 2024
Latest topics
