Best Ohm Wiring for me....
Skits89
NY
Hey guys i have a Hi fonic Brutus 2000W class d mono block amp and 2 12' kicker cvr's. The amp is 1 ohm stable. What would be the loudest and best way to wire my speakers and can someone supply me with a diagram or a quick how to explanation on where to run the wires and how many times. I don't play my system all the time or beat on it. I turn it up for a song and then turn it back down, by the way the subs are dual voice coil 4 ohm so whatever you think....Thanks guys.
Hey guys i have a Hi fonic Brutus 2000W class d mono block amp and 2 12' kicker cvr's. The amp is 1 ohm stable. What would be the loudest and best way to wire my speakers and can someone supply me with a diagram or a quick how to explanation on where to run the wires and how many times. I don't play my system all the time or beat on it. I turn it up for a song and then turn it back down, and both subs are dual voice coils and 4 ohm subs. so whatever you think....Thanks guys.
First, check out Rockford fosgates site and use there wiring wizard to wire your subs to a 1ohm load. Second, find the gain setting tutorial here and follow it. Make sure not to crank your gain as I dont think those CVRs will take 1000w each.
Yeah my plastic sub woofer wire holder things on the side of my box were broke and i hit a bump and they touched positive to negative and blew one of my subs and fried my amp, i opened my trunk cause i heard all these weird noises, i wasnt even playing my system, and i almost cried haha.
Skits89
Skits89
NY
ultimate157
