Best LOOKING subwoofer?
clearly the jackhammer is the best looking subwoofer.
thing looks like a time capsule I would burry in the ground
does it get low?
For earth shattering bass you can't beat this custom made 60-inch subwoofer which has the ability to produce SPL levels above 180 dB. This monster has ouput displacement comparable to 160+ ten-inch woofers! More after the jump.
The motor is capable of producing 6,000+ pounds of linear force, which is necessary when considering the very large surface area and displacement volume required to produce high SPL levels
I call it the big wienie
I wanted to buy that thing too except the T/S parameters doesn't fit my needs. Think this sub can be reconed to something else? One of a kind basket and motor and all...
the t/s specs are from a null motor, needs charged which I will be doing shortly. Can be reconed by corey on here i'm sure which I will be looking into later, has the highest excursion capable design of any 8 known as far as I know.
info on it straight from audio_phil:
- With spacers between the top assembly and motor .. excursion potential is nearly limitless
- a .5" spacer would allow for 2" rearward clearance
- has a 7.5" spider landing and 8" can be modded to work.
- can be reconed for a 3" p-p, the basket can fit a 4" coil and can be tooled to fit most any motor.
- rms on the Adire Audio tumult 3" coil is roughly 600-750rms, it's internally seriesed to 8 ohm.
- It's a beast, as said lol..
i'll be keeping this unless I get an insane offer for it, which I doubt.
sobe3yourself.
lordside gangster
sobe3yourself.
Orange, CA
hispls
NorthFramingham
    Jun 30, 2026
