False.Having said that....if you weren't having noise problems before using a head unit with 'lower' preout voltage (such as 2v or lower) then going to a deck with higher preout voltage won't give you any appreciable advantages.
Thanks for the respones guys. I might check into the Pioneer 880, just cause I always have liked how easy Pioneers are to use. Having said that though, I am not sure how easy the 880 will be to use. I mean I am sure I could figure it out. Thanks again.
Then explain to me what advantage would be gained (assuming there were no noise problems previously) by going to a deck with higher preout voltage?False.
Eclipse 8455 or 8454 are probably the two 'best' decks that can be had AROUND your price range. However if you have to have a detachable face, they are not any good to you any how.
You're FALSE!!!False.
