Best Budget 3kw Deal - Custom White Visonik V4000XD - $300+ship
BassAddictJ
SOLD
Visonik V4000XD
Same board as the MA Audio HK4000D and the Concept 3910
Background:
This amp was purchased new by it's original owner in 2006, and that same year painted white to match the his car. It was ran lightly on a single huge *** pioneer premier 12in @ 2ohms for a few years. It's been in storage for about the last 2 years. Now I have it and it's up for grabs.
Condition:
Board is immaculate and this amp has never been abused. There's a small few knicks in the white paint but over all it's still a great looking amp. Those few marks can be touched up and it won't be noticable. There's no mounting feet, but like other large amps without bracket feet you can tryhunt some down. Visonik might have some, you can do some measurements and make something solid for cheap, or build (or have built) an enclosure around the amp. I did that with my cyclops and couldnt happier. The board of this 4000d is pretty sexy too.
Specs:
These amps are made to do rated power mostly around 18v, but still run great on a 12v semi stock setup. The 2 ohm rating 14.4v is 3500wrms, but realistically it's going to be closer to 2500w-3000wrms on a daily 12v-13v setup. I've read people using like 1 or 2 good back batteries, 1/0, and stock bat/alty without issue and getting good results. You can try to mod it and run it under 2 ohm, but I typically avoid that since that ussually results in shorter amp lifespan. The good news is it'll work well off semi decent budget electical, but will shine even more when you give it more juice.
For the money this amp will do ALOT of work.
Manufacture ratings:
Rms Power @ 14.4V DC: 1 x 2500W @ 4 Ohm, 1 x 3500W @ 2 Ohm
Rms Power @ 17V DC: 1 x 3000W @ 4 Ohm, 1 x 4000W @ 2 Ohm
Dimensions (H x W x L): 3.125" x 10.5" x 26"
12 - 17V DC Power Input
0.2 - 8V RCA Input Voltage
Frequency Response 10 Hz - 350 Hz
Short / Overload / Thermal Protection
Strappable with second Class X Amplifier
24dB Variable Subsonic Filter
24dB Variable Low Pass Filter
0 - 18 dB Variable Bass Boost
RCA Line OutPut
Asking $300 +ship. I'm open to offers, the closer to FL you live the better deal I work work as shipping will be less. It is a large and heavy amp, but I'll do the best I can to get it there safely and affordable.
No trades, sorry guys
Prefered USPS Parcel or Priority Insured, but I'll ship whatever is requested.
**** shots coming up next
Ref's: Years of selling here, you're in good hands.
PM me with questions or offers
I hooked it up @ 4 ohms to my d2 trf for a little test run, everything played normal. Buyer shouldn't have any issues with it. Don't have the coils to let it stretch it's legs though //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
ehhh...you can mod it (same way they mod the hk4000's) and if you keep up your voltage it's probablt stable at 1 ohm......i generally recommend against it since modding and abusing typically shortens the amps lifespan.
BassAddictJ
BassAddictJ
FL
loudstratus
