Don't correlate 'hit' with impedance //content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gifThose SI mag subs only operate at 2 ohms. That wont give me the hit im lookin for. I know putting them in a sealed enclosure is gonna give me what im looking for but how much will it cut down on volume. Is it worth it?
Really? Were you able to measure it? If so, can you post the graphs? I'd be most interested in the 2nd and 3rd harmonics of that metal cone. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifThis Guy is selling this 15" that can handle 1500 and I know first hand it has very little distortionhttp://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=170214598087&ssPageName=STRK:MEWA:IT&ih=007
Might be worth waiting a month or so and getting the new Stereo Integrity Mag subwoofers. They should be available by then, and would fit under the rear seat of your truck.
(1) Sundown SAZ-1500D - $300ish
http://www.sundownaudio.com/pp1500d.html
(2) 12" SI mag subs - $250 each
http://www.stereointegrity.com/mag.php
http://stereointegrity.com/forums/index.php
The sub will do perfect in a 1 cubic foot enclosure and 500 - 1000 watts. The sundown will be able to throw about 750 watts to each sub, and you have enough room under each seat for them. Factor in wiring, an deep cycle (or additional) battery, and you're still well under budget.
That would be an absolutely amazing substage.
Are you looking for headunits, component speakers, or a component amp?
Yep. The new Mag's will be available for that amount once they arrive.Is that reallly what the 12's are going for from SI?!?!
The OP is referencing the 'hit' from subwoofers to impedance. mrorgowski is trying to tell him not to confuse impedance with a type of sound or 'hit' from subwoofers.Don't correlate 'hit' with impedance //content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif
What do u mean? explain please.
I also suggest the 2 mags off the SAZ 1500d. Would be pure *** and perfect for your truck being you don't have a lot of room to work with.OK under the left side of my backseat I have 1 cu. ft. Under the Right side I have 1 cu.ft. Under the middle I have .66 cu.ft. This all adds up to 2.66 cu.ft. and I still need to fit the amp under the seat as well. Im running a stock alternator at 90 amps.
