Best Amplifier Kit? PLZ HELP!!
jamesdean
I know this is a very broad and general question, but I'll try and be as specific as possible. Ok, I'm running a Kenwood Excelion HU running to ( and this is up in the air still) DLS UR5S 6.5s in the front, then 2 5.25s for the rear fill. My front stage will be running off of an ARC AUDIO 4150. For the subs, I have 2 10" Resonant Engineering SE's running off a DEI 1100d for the time being. Given such info, can anyone tell me the gauge of wire, brand to produce cleanest sound, etc.....
Thanks for any info.
http://www.knukonceptz.comhttp://www.darvex.com
Both sell good ones //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Although to run both, I'd look into buying the components seperately, you're going to need a 2awg power wire or larger...
Thanks, what gauge for the front comps and then for the subs. Should I buy 2 kits( 1 for the front and 1 for the back)
Just get a single 2awg or 1/0 gauge power lead, then split them with a distribution block at the amplifiers.
That's why I'm saying buying two kits would be overkill, because you'll end up with more parts than you need.
Get the kicker 0 gauge kit, its the most flexible wire ever, when it comes to wire of that thickness, its important. Stinger expert 0 gauge is good too, get whichever is cheapest of the 2.
jamesdean
jamesdean
tampa,fl
spyderz9
BP1Fanatic
BP1Fanatic
