best amp to run for 2 12" RE SE subs.
Why bump a thread that was only down 4 spots from the top? //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
cause he doesn't understand that if there was such a thing as "the best", that would be the only product on the market. plus the search button is really hard to use.
Not to mention he is in the wrong section. Might want to give this a try in the "AMPS" section //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I went with a audioque 1200 for $250.00 i dont know of another amp to beat that price for the value you get i also have 2 re se 12" subs going into a sealed box just have not installed yet and i already have one gauge wire from kru koncepts
thanks dude, thats what i was thinking. too bad those other two turds had to throw a fit about this being in the wrong section, they could have just acted their age and answered my question, i mean that is what these forums are for, right? same people that got beat up all through grade school and are angry at the world.
And someone can't read, has the patience of a 2 year old, and has sand in his vaj. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
first of all i put it in this section because i was asking what gauge wires i would need, im pretty sure that would fall under installation help. second i bumped it because i needed an answer quick, no reason to be a sassy school girl, chill out, i didnt mean to ruin your day, my apologies .
Don't worry, I am all chill bro. I don't take this shit very seriously. You have to have thick skin around here.
For the wire, use the wire size that the amp accepts and fuse accordingly.
Right, so for the power cable i use the same size fuse as the one on the amp?
Nope, fuse based on the capacity of the wire. Some MFG give them, some don't. If you buy Knu wire, they give the capacities on their website IIRC.
Basically, if the wire is rated up to 125A, use a 125A fuse. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
go with an aq1200d you will be more than happy with it. As for wire if you are running more than one amp I would do 0g to a distro then 4g to each amp. If you are just going to run the one amp and not upgrade in the future then 4g with a 125-150 amp fuse should be fine.
Ryan1126
Banned
Ryan1126
San Diego
mcsoul
