Best 4 gauge wiring...
Kross6622
Simple, I have an orion 2500d which has 2 - 4 gauge inputs. Im running 0 gauge to the back and got a distro block to 2 4 gauges....
right now i went i got CHEAP 4 gauge from the gibraltor(fleemarketesk) (bought a whole kit for 15 bucks) and I simply just cut it up and doubled it up for right now...
So right now I have 4 runs of shitty 4 gauge twisted together (2 x 2) to the amp...
It looks like crap but does what i wanted it to do...
whats the BEST 4 gauge wire. I want thick flexable wire... prefer if they sell by the foot as I only need a couple feet in total (10 ft or so)
Color doesnt matter just need thick 4 gauge. Price isnt really a concern.
look around on ebay becuase i just got 25 feet of monster 1/0 for 60 bucks which is pretty dsamn cheap. ive never used it before so if i like it and its got a comparable amout of copper to knukonceptz shiit ill prob buy 100 feet of it
knukonceptz is always great. The Kollussus is only 1.40 a ft, or if you want to go a little cheaper, the KLMX (Copper Clad Aluminum, still great wire) is only .89 a ft.
I currently have Knu Kolossus, Knu Fleks, and Kicker Hyperflex in my car. I used Monster 1/0 in a co-workers ride. Hyperflex is the MOST flexible, followed closely by Fleks. Kolossus is a little stiffer, but does the same job, just as well. Monster is probably the LEAST flexible of the four. Monster also has that stupid plastic rod that runs through the center of the strands, so you have a slightly lower strand count. I only used the Monster because I got a really good deal on it. I would never pay anywhere near retail for it. If you have some CRAZY curves/bends in your install, Kolossus will work, but it is tougher to work with. If you're on a budget, use Kolossus, if you have a little more, use Fleks. If your budget is unlimited, use Hyperflex.
I need it by the foot, i have 0 ran to the back then have a distro block to 2 - 4 gauges. Need to replace the 4 gauges. I only need about 10 ft power and 4 feet ground.
Kross6622
Kross6622
SCS, MI
lovindabass
