Best 12 inch sub for $125ish
Wait so I build the box to that size, and use 2 pvc ports on the front side with flared ends? What size exactly should I do the pipe?
I never said two ports. The pipe will be your single port, its just 5x cheaper than buying the online premade pvc ports. You also need the port to be that certain inner diameter I specified on my post.
Alright so if I get like 5 inch of pipe and flared ends, then you will tell me how long to make them?
Also should I do the back of the box slanted to allow for more depth in the box?
yes If you can find 5 inches exactly, it will need to be 12.5 inches long. But length will change depending on diameter.
Jbabyluds
Jbabyluds
Jacksonville Florida
AnthonyO
