Benefits on using a bigger box?
Sometimes going too big is a little excessive, unless you really dont care how it sounds, and just want it LOUD. For daily driving you want to have a box that fits the response your looking for, and then gets as loud as possible hopefully keeping the sq your willing to trade off for the loudness. Huge boxes with tons of port area are very SPL oriented and generally are more one note or small bandwith monsters. Having my R's in 4ft each is definatley louder @ 30-40hz than when i had them in 2.2 before, but the transitent response with double bass is slaughtered and the 50hz+ is gone. Now they really only shine on low solid bass lines, but still have a clean hit to them as long as its not extremely fast double bass.
In one sentence, Bigger boxes are generally more efficient but handle less power.
A smaller box with more power on it will sound clearer, but may not hit as low as you want the bigger more efficient box to hit.
Its different for each sub/vehicle and really just depends what you like, maybe letting us know what you have for avehicle , what you have for power, subs, and music prefrence would help us send you on the right path, unless you were just wondering what a big box does.
Would you recomend a CVR12 on a double the size box according to the manual
box size is dependent on mostly mechanical aspects of the driver...QES/QTS also have to do with it, but its not a huge factor... its simply the electrical damping, the higher the Q the wider the bandwidth of it's resonance is... this is why alot of SPL woofer tend to sport the lower Q figures, not more efficient but a narrower bandwidth so its easier to get a higher peak. someone here tried to make and SPL woofer with 10" spiders and a FS of 20hz, hehehehe
i have a cvx 15 in 5.6 cuft. ported box tuned @34hz i wonder the same thing about box size its loud and plays deep for i sub i want to go with 2 15 but because of space i can only do 3.5cuft per and i love the way 1 15 sounds im afraid that if i get 2 15 with 600 watts going to each it wont be as loud as my 1 15 with 800 watts going to it
bigger box is going to have better low end
smaller box will be peakier, low end will go down and gain some upper end
i usually just try to fit the biggest box i can
my 2 MT 15s had 5cubes apiece, im going to 2 18s and they are only going to have 6cube apiece
I read allot of you guys taking about 20hz , 34hz , where do you guys that info from?
Octavio
Octavio
Nic
dvrmstrng
vegang
vegang
