something wrong. argh!
LowEnd85
ok. ive checked multiple times on my rcas, ground, etc. everything is good. the bass output is very low.. even when i turn all my gains up, and my bass on my HU (just to test of course) but even then, itll be loud.. then lose power again. i reset my gains to its right place, and the bass, and all of a sudden the bass came back, then went low again. do u have ANY idea why its doing this. its a DVC sub wired in paralell, running 2ohms off of a mono amp. (Maw12 and profile audio 400MSX) i might have wired paralell wrong by accident but i highly doubt it.. i rechecked it before i mounted the sub. when i first installed and mounted it and tested it, it was great. i turned off the car, got back in to go to the store, and the bass was gone. even when i turn the bass up it barely hit, then it would come back again, then die again. argh
argh =
bump. i need to fix this. ive checked all wiring. nothings loose. only thing i can think of is im using 8ga wire running from the amp to sub box. then 12ga on the inside wiring the sub. i dont have an alan wrench to get the 8ga wire out and replace it
rewire the sub and tighten the wires in the box
my frienb had the same problem //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
this has happened to be on another amp as well tho. happened after a friend showed me how to wire subs, and he wired it in series for me. thats when it started dimming the power. now i have it in paralell on a different amp. series, and 8ohms, on this amp is no good. no power at all. i need it in P at 2ohms. i just re wired the sub, changed it out with new wire. when i get a chance to turn it up ill let u know.
darn man, you've had some problems going on. that sucks. i hope you get it all worked out. if you need amp recomendations try a refurb kicker 400.1 on ebay. they are going for like $100, and will do more than the 400 rms it says. only if your amp is shot though.
i just got this amp. i dont see how it could be bad? its a refurb also. it hits hard as hell when it works... when i go up and downhill thats when it hits hard, then when i drive straight the bass output lowers incredibly. sometimes the bass will randomly kick in just driving forward, but mostly when i go up and downhill. its gotta be something loose but i dont know what everything is in place
LowEnd85
LowEnd85
florida
neonrt
BP1Fanatic
BP1Fanatic
