Benefit of IB vs. Just sub in Box.
Bhhong
I see these 8" IB's and I saw team psi....I just want to know if there a difference in sound....I know the setup is different but are the IB just meant for SQ or actually being loud....? Thanks for the info....
Used the search nada too broad for IB
There are quite a few benefits to an IB sub. Yes, it requires less power to reach a given excursion. This means less thermal compression and also less current applied to the driver. Less current lowers non-linear distortion due to Le(i) also known as flux modulation. You also have no compression of the air in an enclosure and no box walls to resonate.
The Cult of the Infinitely Baffled forum has a good FAQ on IB subs. http://home.comcast.net/~infinitelybaffled/
John
Bhhong
Bhhong
SD DAYGO CALI
John_E_Janowitz
