Benefit of Double Baffles?
sku
Check out my 'woofer
I've been curious about this for awhile...
I see many folks using double baffles on here...
I've built many boxes ranging from 3 to 7.5 cubes (fully braced) and have never used double baffles...
What is the benefit that people see from the double baffles?
Thanks.
Hmm, I've never had any of these issues with a fully braced box...
Has anyone ever added a second baffle (say to the front or some panel that was flexing) and just went wow -- that's so much better? If so was your box brace very well?
I know that the second baffle provides for a denser/stiffer box (in theory) but in reality (depending on the circumstances) you may not even need it...
I would much rather double baffle then put rods, or wood supports inside the box that would impede air flow etc.......
If you use wood screws to mount the sub, it gives you more depth of wood to support the driver. Makes that panle less likely to flex from the weight of a really heavy driver as well.
Yep, I can agree and see that it's a good idea for a woofer side double baffle...this doesn't make the boxed fully braced though...
I tend to see less of a value in double baffling all sides of the box...
To each his own, I guess...
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
I’m at 3 yrs on my Tucson alternator. W the electrical challenges i faced it’s been worked hard. Thankfully those challenges have been overcome...
99
9K
sku
sku
Seattle, WA
smd4life
    May 20, 2024
    May 20, 2024
