Bench testing my own amp?
Are you wanting to simply make sure it works, or measure the power output ?
You could do either, but the later would requirement equipment I'm going to presume you don't have access to.
the cheapest way to do is it is just have it hooked up to your subs so its at reactive load, not nominal, and then use a clamp meter and dmm. then do voltage * amperage = watts
THXdts
THXdts
Maryland
PSturmer
