Beginner's guide to box building
Thanks, man. I'm so glad I joined. I really appreciate good, solid information like this. //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
No problem, glad I could help //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Okay, here are the main box formulas, courtesy of DIYsubwoofers.org :
Vb = 20*Qts^3.3*Vas
Fb = (Vas/Vb)^0.31*Fs
F3 = (Vas/Vb)^0.44*Fs
dBpeak = 20*LOG(Qts*(Vas/Vb)^0.3/0.4)
Vb = net box volume (litres)
Fb = box resonant frequency (Hz)
F3 = -3dB frequency (Hz)
dBpeak = maximum peak or dip in system response
Vas = Equivalent air compliance (litres)
Qts = total Q of the driver at its resonant frequency
Fs = resonance frequency of the driver (Hz)
Dv = internal diameter of port (cm)
Lv = (23562.5*Dv^2*Np/(Fb^2*Vb))-(k*Dv)
Dv = port diameter (cm)
Fb = tuning frequency (Hz)
Vb = net volume (litres)
Lv = length of each port (cm)
Np = number of ports
k = end correction (normally 0.732)
The value for k, the end correction, can be fine-tuned by using the following values to derive the appropriate end correction figure for each end of the port, then adding them together
Flanged End: 0.425
Free End: 0.307
e.g. if both ends were flanged,
k = 0.425 + 0.425 = 0.850
if one flanged, one free,
k = 0.425 + 0.307 = 0.732
if both ends were free,
k = 0.307 + 0.307 = 0.614
Normally, k=0.732 is assumed
Slot Ports
If you wish to use a slot port, first determine the diameter of a round port that has the same cross-sectional area as the slot. The following equation can be used to do this:
Dv' = 2*((W*H)/pi)^0.5
where,
Dv' = diameter of equivalent round port
W = width of slot
H = height of slot
Vb = 20*Qts^3.3*Vas
Flanged End: 0.425
Free End: 0.307
Slot Ports
where,
W = width of slot
H = height of slot
Once you've calcula
Woot Woot.
**** dave I havent seen you in awhile where you been hiding?
I've been working on getting into college, and now that I'm in, and more importantly, where I want to be, I decided to come back. After having seen the state of the forum upon my return, ain't nothin changed //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
do you need more help building boxes lemans?
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif :laugh: I'm alright, I could use a little more caulk though.
caulk //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
Ok im confused on the calculations it says diameter wouldnt that be for a round port?
You need to use the last formula to find out the equivalent surface area. Then, you just plug it back into the original equation //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yeah Im pretty much over it at this point. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif I have no tollerance for anyone anymore.
PV Audio
The Vision of Sound
PV Audio
Indy
alvitae
