What's the purpose of having 3 baskets ? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gifMemphis 15-LVS18X3. Not exactly a huge motor (although it is a decent size). But the triple-stacked basket should impress.
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2124
its just a MT with a new basketChad > everyone else
I see you added a new triple stack with new basket to your team there chad.
O ok so the xlSPL-12 it on top and the napalm is no bottommach 5-topnapalm-bottom
if you had read then you wouldve understood
May I ask what you base this completly retarded claim on?its beefy, but not powerful //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
21tMMay I ask what you base this completly retarded claim on?
Boy this just goes to show that post count means nothing.21tM//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif that was for the earthquake
Boy this goes to tell you that you obviously didnt see that i wasnt talking about the sign motor...Boy this just goes to show that post count means nothing.
There are so many different things different between the earthquake and a sig.
The eq uses a 4" coil. Sig doesn't.
The eq uses a different material top plate. Which has less somethingorother in it and doesn't magnatize(sp) near as well as the steel used on the sig. I'll admit I'm not a genious and don't know what it is called but yep its there.
Mike said after he helped them design their version they changed it all to make it cheaper.
Please don't downtalk a sig motor.
