Beauty Rings on my subs...
on your type-r's?.... why are they falling out? wash them with soap and water in the sink, and dry them off. they should pop back in and stay. did you use something to shine them up?
Also, where I remounted them, there's holes that air escapes from, so when the beauty rings are in correctly, the air doesn't escape. when they pop out, you can tell air is escaping because of the sound...
there is the problem. air should not come through the holes. the beauty ring is just that. there for looks. at full power, the rings do not budge. however, if you are trying to use them to seal, they won't. seal the box opening. if it's not carpeted, use foam tape
Can you explain that in more detail? For now, I will just get some weather stripping until I have more time to fix the issue completely.
Basically means take the panel (baffle) that your subs are mounted to, make another panel but with the cutouts a little smaller and attach it to the current front panel.
If your subs are mounted to the front of your box, get another piece of MDF that same size, but make the cutouts a little bit smaller and then glue this new baffle to your box.
kat_black181
Car Audio's Only V@gina
kat_black181
Sevierville, TN
CHEMMINS
