Bc3500 ????
[quote name='Dirtrider4eva']yeahe you'll be tickling 50, but at such a low tune id expect 48.5s, theyre solid amps.afaik same as a aq3500.1[/QUOTE]
VERY different than a aq3500
@pro\-rabbit; can give you a better run down of it all. But the AQ is superior than the BC in just about every way shape and form...
friend is running 1 at 1 ohm on 2 chaos 10s in a mustang. 4 huge dekas and 0 gauge through out with a stock alt till his 300 comes in. he starts at 13.9 and drops to 13.3ish. hasnt tuned it with his dd-1 yet though.
[quote name='Kangaroux']VERY different than a aq3500
@pro\-rabbit; can give you a better run down of it all. But the AQ is superior than the BC in just about every way shape and form...[/QUOTE]
hope rabbit chimes in on the aq i want the BC but was goign to go with the AQ since BC on backorder :p
nice on the bnib ones . thinkin the AQ may be a tad under rated needing 2 runs of 1/0
You.re talking about the new aq with dual inputs its rated at 4300 im talkin bout the old aq3500 with single input...besides ill have 2 runs goin to my bc3500 ..because my has dual toolmaker power and grounds
NASTY08IMPALA
NASTY08IMPALA
LOUISVILLE, KENTUCKY
NASTY08IMPALA
BP1Fanatic
BP1Fanatic
