Batttery ?
smokeoff
here's my 3 cents
1,114
Cambria,WI
I was wondering is their a battery out their that is designed to run subs off of but can be used as a regular battery. Also about how much does it cost to get a higher power alternator installed(alternator+labor) so I can get a bigger amp and be able to run it.
i think you need an amplifier cuz you need to send the signal to a subwoofer to play the note or tone. A battery, will send energy //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif this is why you might need an amplifier for subs.
hooking up a sub to a battery, i dont know it that does anything but i'm certain it won't play anything.
Check into Optima batteries. They have batteries designed for starting/accessories and for accessories only. As for price, I'm not sure but I think I've seen them for about $200+. Check out http://www.optimabatteries.com. As for alternators, it depends on if you want a slightly more powerful alternator or a high output alternator. You can get your alt rewound for less $100. A new alt will go for about $200 - $400. Installation is not too hard to do yourself. If you have a shop do it figure about $65 per hour labor and depending on your vehicle 1-2 hours.
smokeoff
here's my 3 cents
smokeoff
Cambria,WI
budgetSQ
    May 24, 2024
    May 23, 2024
