adio25
Just got a new kinetik HC2000 and the voltage seems low with even the smallest loads. With the car off, HU on, amps on, volume set to 0 so there's no output from the amps, my voltage will taper from 12.8v down to 12.2v in a matter of 30 seconds. If I do the same thing with my headlights on (probably adds around 100-120w) it will drop to about 11.7v. When full tilt with the car on cruising on the highway it will drop a full volt with a stock 130 amp alt. Maybe I'm just crazy but is this normal for this big of battery to do on such small loads? Also one thing to note is that its below freezing where I live right now (5F-32F)
