Battery terminals?
You can connect 3 1/0 awg wires to a plain jane 3 dollar battery terminal from auto zone. remove the 2 bolts use to clamp down the terminal, put ring terminals on two 1/0 wires and run the clamp bolts through them and an additional 1/0 wire witout a terminal in the normal terminal location (the spot where the wire is designed to go) so when you clamp down your wire you tighten the bolts down on the two ring terminals. Voila, better than any Kunkoncpts terminal.
Thats a nice tip for people on a budget. I like it. as far as actual terminals, JL makes a 3 1/0 out term. and so does knu.
That's what I'm doing now. I have my amp power run, and an additional alt. run since I only used 4 gauge, so I just kept the original 4 gauge run too. I think I'm going to use a copper bar for extra runs.
95BlackGA
95BlackGA
Missouri
95BlackGA
