Battery Reserve Capacity
swx1042
CA
When companies refer to Reserve Capacity (i.e. RC: 60 minutes),
Is that how long you can use electronics and still be able to start your car?
or is that how long until your battery is rendered useless and your car ends up needing a jump?
thats how much it stores after the car is off/electronics still on to use.. so if you don't start your car or turn all off after about 50 minutes you will have a hard time starting and 60 minutes it won't without a jump..
don't try and run a system on high levels though.. or you will be toast.. basically look at cca.. say they are 550.. if you have a system bumping it can pull anywhere from 100-300amps+ and you will have a few minutes MAX
Google is your friend:
What is reserve capacity?
Reserve Capacity, (RC) is a battery industry rating, defining a battery's ability to power a vehicle with an inoperative alternator or fan belt. The rating is the number of minutes a battery at 80 degrees F can be discharged at 25 amps and maintain a voltage of 10.5 volts for a 12 volt battery. The higher the reserve rating, the longer your vehicle can operate should your alternator or fan belt fail.
haha, thanks man.
i saw that page and read it, but i wasn't clear if 10.5 volts worth of a charge would start a car (and to what conditions you'd end up at that said 10.5 volts)
swx1042
swx1042
CA
swx1042
