battery power question
crunch5868
ok so im wiring up my system and i have a deka intimidator that i was going to put in my trunk but I would have to buy more 1/0 wire and connectors and another fuse to wire the second battery. Would i be okay just putting the deka in front in place of my regular car batt., would that give me sufficient power?
my setup is: an audioque 2200d running to 2 pioneer ts-w3001d4's (1000 watts rms) at one ohm. all kicker 1/0 gauge wire. my batt is a deka intimidator 9A31:
# BCI Group Size : 31
# Voltage : 12
# Cold Cranking Amps @ 0° F : 800
# Cranking Amps @ 32° F : 1000
# Reserve Capacity Minutes : 190
# Amp Hour (20 Hour Rate) : 100
im not going all out like competition style or anything its just daily driving.
And the weaker of the two batts will pull the other one down with it, inturn the alt has to work harder to charge two batts therefore if it is really to much then the alt will eventually burn up
either another battery as well as the deka
or a stronger alternator
...power it up and find out
the deka could b alrite
wut kinda car is it going in?
hes talking about replacing the batt with the deka...can u read?
only way to really know is get a volt meter hook it up that way play the music at listening volume and see what happens to the voltage.
Can you read he is asking if he will be ok by replacing the batt up front instead of wiring them together. That = 2 batts one under the hood and one in the trunk
yeah instead of using both batterys i want to replace the stock one with the deka and only use the deka in the front. only one batt.
I love my deka..but i dont see it supported 2k unless youre very easy on the gains
ok so im wiring up my system and i have a deka intimidator that i was going to put in my trunk [/color][/u][/b][/b]but I would have to buy more 1/0 wire and connectors and another fuse to wire the second battery. Would i be okay just putting the deka in front in place of my regular car batt., would that give me sufficient power?
thanks for the help but.... no lol. im talking about only putting one under the hood, the deka, thats all.
crunch5868
crunch5868
413, Massachusetts
crunch5868
