battery keeps dying. wtf?
billy98sport
the bang of the small one
ok i know that if u run too much power it will kill your battery. but i didnt think 1200 watts was too much. is my battery just shity or should i go with the whole new alternator thing or what ever your supposed to do when you car dies.
im thinkin i just need like a really good deep cycle battery to do the trick but im thinkin of wirin sum neons so would that require so much more power that i would need to go with the new alternator?
thanx
Sounds like to me you need to upgrade you alt. If you get a good batt., you'll still be cheating yourself becasue if the alt. can't recharge the batt. you might end up in the same boat over time. If you have a true 1200 watts then yes you do need to upgrade your electrical system. if you add neons to the current system, your problems will get worse. You can't make the power if you don't have the power. Also your system will more than likely hit harder with an upgrade!
Hmmm, that part about the system hitting harder intrigues me. I love learning how to optimize what I have. Would an upgraded alt cause a system that is NOT stressing the current electrical system ( less than 600w) to hit harder? I got a couple of OLD 12's that still thump good enough to satisfy me, but if I can squeak a 'lil more thump out of 'em... I'm up for that!
Thanks in advance.
probably not...if your alt is not up to par..your amp is probably not getting the max. voltage it can from your electrical system which will cause it not to produce as much power...thats all he was refering to
i talked to a guy at autozone about a new alt and he said that a friend of his got a hi performance alt for his system and he burnt the alt within a few weeks. he said that on his own system he got some kind of power supply thing that takes less power from your alt and then amplifes (not in watts but in electrical current) the small amount of power from the alt and then pushes it to the amp thus causing less strain on the alt but still delivering peak power. ive never heard of this. could this b a possiblity or is he just stupid? where can i find decently priced, good alts? and about what size would a i need i saw a few that were like 200 watt and 300 watt, what kind do you sugest?
Sounds to me like the guy was full of crap. A decent alternator will not burn out or blow like that and he was being of no help to you. The only thing really you can do in between is a capacitor, but again you need a good alternator to push that and keep that charged.
what's up guys------------ first lets just say we aren't talking big power here.... don't need a new alt. Step one would be checking/replacing wires and or terminals from the alt to battery---- this includes grounds on the frame.motor and body------ this will eliminate any possible POWER ground loops cause a voltage drop in the charging system---- second would be to add a 2 farad cap to buffer the current demand from the system. if the car is have trouble charging 1 battery its REALLY going to have trouble charging 2 or more. The little black back that was spoken of it bulit by jacobs racing--- the accu- volt. What good is the high voltage out of an accu-volt when you can't draw much current??? Believe me ------ all electronics output a signal/power at a loss --- so there isn't any sense in sticking an accu-volt inline of and amp. Not a bad idea for your processors and HU though
Yea its been awhile sence we seen ya on here man!!! Glad ur back!!! Hey does anybody know what a Corsica's max Alt. size is? I wanna replace mine beacuse, i am going to go with 4 amps neons and some other goodies possibly too, so an upgrade is gonna be in order.
Amps
Subs:
Shadow 1000 watt
Mtx thunder 2200
Rear comps:
Kraco 140x2
Fronts:
Optimus 20x2
This last 2 amps are temporary till i get loans paid off then i am gonna go crossfire or something new.
J
yea ----- I just stop over on the forum when I have time-------- going to school for dual major ---- chemistry/physics---- while working full time for chrysler on the durango assembly line---- plus studying to be a private pilot--- commercial diver and looking into getting my first house //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Originally posted by Corsica Yea its been awhile sence we seen ya on here man!!! Glad ur back!!! Hey does anybody know what a Corsica's max Alt. size is? I wanna replace mine beacuse, i am going to go with 4 amps neons and some other goodies possibly too, so an upgrade is gonna be in order.
Amps
Subs:
Shadow 1000 watt
Mtx thunder 2200
Rear comps:
Kraco 140x2
Fronts:
Optimus 20x2
J
most likely 90--100A you can call your parts store and ask what it is
Hold up a minute. If it stayed on when hooked up to the remote wire on the head unit, that's a problem. It means your head unit is staying...
I'm thinking that my Pioneer DEH-P880PRS does, for a little while. Not for months though. if you can find them, they are not cheap. Just pulled my...
530
billy98sport
billy98sport
Jennings,La
chris229
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
