Battery Keeps Dying, Voltage not as high as it should be?
Yes its my main and only battery, but i don't usually play my system with the truck off
i was saying thats what the yellow tops are good for (playing your system for a longer period of time with the vehicle off). they drain much slower than say a red top and as a result, take much longer to charge. a red top is good for a DD because it charges up real quick and is more reliable IMO.
if you think a battery load tester is a waste of money you are silly... i pulled one dead batt from an array of 5 total in my crx and GAINED a healthy amt, not to mention my voltage came up alot after it was pulled... its a cheap and useful tool.
sure it is a waste if you can use a DMM to check voltage.
disco all batts and wait a day or so and check with a DMM
they should all be within 1 or 2 tenths of each other.
LinxuS
Jellysickle
LinxuS
Las Vegas
iamamp3pimp
