Battery drain question...
Foote
Ok, check it...I've had problems with my battery draining (no sound system in it, btw) in the van....anyway...it'd just keep going dead over night. But...when i charged it to like 12v the van would boost it up to 14 so i guess that means its not the altenator. So, I tried another battery (not new, but I think it was good..) and got the same problem...
Tonight I went out and looked around and noticed the negative bolt in the battery side post was "wiggle-able" so, I tried to tighten it ( I should mention that I recently purchased this van by the way)...and it wouldn't tighten. So, I take it out and it turns out the bolt was too short to sit tight in the side post's hole thingy. So, I went to advance and bought a proper one...put it in and now its snug. ALSO I noticed a spot where I'm guessing the driver side head light is grounded..with the negative battery cable...right there above the headlight under the hood...well the what I call "headlight ground cable" was ridiculously loose (by the way, that driver side light had been going out and being dim off and on)...So, I tightened that up too and then the light is bright now //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ULTIMATELY my question is: Could these loose grounds have been what drained, even with the car off, my battery? Is my problem most likely fixed? Or should I expect to wake up tomorrow to another dead battery //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif ? ? ?
Thanks for any help.
Fords and Chevy's are even more so likely to have this problem.. That is why I ask. I would put my money on that something is drawing power when the vehicle is off....The terminal issue wouldn't cause your problem but anytime you have a positive wire touching a ground can cause issues...Which could be a cause for your battery drainage. Just a guess w/o seeing the van up close. My dad would have a better idea if you still have a problem tomorrow. Ill check in.
I had a short in one of my window switches that drains my battery over time, I cut the wire that was screwed up somewhere, and haven't gotten around to actually fixing it yet
it has nothing to do with the things you mentioned fixing, in fact, those things may have been slowing down its effects if anything lol...expect to wake up to another dead battery
we have an electrical help section btw;)
actually..it started this morning with no problem. Hope it continues to do so. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
you do realize this is the lounge right?
on that note, I recommend you check for continuity in your battery by touching a large metal object connecting both terminals. Remember, sparks means its working
Foote
Foote
Horn Lake, MS
Mynameismcgyver
