BAtteries....... what are my options.
Omarvelous
Ok guys.
Bout to start my electrial upgrade. Looking into replacing my stock batt and Big 3.
Got a Tahoe 04.
Was originally gonna go with a Odyseey PC1200MJT. But it doesn't have the side post that the factory GM trucks use. Optima would be perfect since it has the top and side post, but i'm a man about value. The odyssey cost about the same as the yellow with more CH, i don't however know the acutaly CCH. Any1 know?
Anyway does any1 know of a battery with top and side post like the optima but with a much higher CCH?
What i was thinking of doing is cuttin off the factory piece that is used to put in the GM post and actually place the exposed wire into a terminal, then have my big 3 upgrade and i could then hook my amp wire directly to the batt. What you think?
A regular red top OR yellow top would do the trick. Are you keeping the stock alternator, and if so...are you going to put a good size load on it? If so, you should use a yellow top as your starting b/c of it's ability to deep cycle. If your going to upgrade your alternator, or if ur keeping stock and not putting too much of a load on it...just use the regular red top starting battery. peace
NG
Battery options; SVR, Hawker/Stinger, Lifeline, Delco Freedom Extra for sealed, Deka, Trojan, Interstate, Excide for wet.
I know quite a few Optima haters //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Omarvelous
Omarvelous
Queens, NY
supa_c
