bass mekanik tones 0 db?
  • 4
How much voltage should I have for a mono 1000 watt (actual 1128) into a 4 ohm load (measures 3.6)?
I calculated around 62-64, but only get 20....
Suggestions?
Turn the volume up on the deck higher and the gain on the amp higher till you hit your match of around 62-63 ish.
But i doubt that amp will fully put out the 1k. Id put it at about 900w
Just post the model of the amp, it might only be like a 400w amp. And that makes sense considering monoblocks really drop off in power at 4 ohm..
If possible try to run in 1 ohm (assuming you have a single 2 ohm sub)
Alpine PDX 1.1000.........actual test values 4 ohm load, 14.4 volts, RMS output=1102 watts...........................
It is rated at 4 ohms, but is supposed to output the same at 2 as well.
Got it figured out....................
WOW!
It hits SO HARD!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
There was an issue with the sub output..............at the 0 (no boost level) it was puting out lower preout voltage. I switched it to one of the full range outputs and it went right up to 60 volts...........I actually turned it down some!
The EPIC-160 does wonders!
Kodas like big sealed boxes and can't handle power. I shredded the surround on my 8 in .4ft³ and 350w My 10s on 1000w for the pair one coil...
271
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
598
Defiantly. LOL 😂 It has never happened to me👀:poop:
686
pegasis50
pegasis50
Richmond, Va
pegasis50
    May 31, 2024
    May 24, 2024
