Bass dosent wobble
See, the amp doesn't have an actual 2 ohm rating, that's why I said about 600, in actuality it could be closer to 500, regardless of what the amp is capable of though, you should be going for 24.4v or 300w, that's what the pair of comp 12's RMS rating is. Definitely do boy run the comps way above rated, They are not built for it, Kickers ratings are relatively accurate when it come to power handling.
is it even rated at 2 ohm bridged or are you just telling him that? What amp is this?
Well when I bought the amp I was on the understanding that it could run 2 ohms.. Yes I said in numerous posts that each sub is getting about 300 rms and I said a combined rms of about 600 rms.. My biggest problem I'm having is trying to get the DMM to read correctly.
So basically I couldn't find my number I was looking for on the DMM because the amp cant even put out that much power in the first place?
So I guess I can just crank the gain full power and don't even have to worry about over powering my subs since the amp cannot put out that much power anyways , right?
NO Do not crank the amp. You can still damage the sub due to clipping.
Well thanks for a lot of nothing underfire, just a waste of time and money $
If these are the REAL specs,
75x2@4ohm
150x2@2ohm
350x1@4 ohm
If I bridge it at 2 ohms, what should I look for on the DMM?
I just want to listen to bass until I find someone off CL to buy some of this shyt
Can you confirm i'm doing it right, i don't fully 100% understand how the power acts when you bridge and drop the ohms etc.
150x2@2ohm
So SQ of 300? Im looking for a 17 on the dmm
darron016
darron016
minneapolis, mn
calebkhill
