Bass dosent wobble
American bass xfl dual2 185bucks auiopipe apsm1500 125 i think then build a nice box for it ..will be 10times louder than what u got ..i personally hate the audiopipe amps but for u they will rock ur car conpared to what u got bro
is it even rated at 2 ohm bridged or are you just telling him that? What amp is this?
It's a Treo TSX75.2, more than capable of running @ 2 ohms, there is no actual rating though. I've never lied in any way, even in the post where he linked another thread, that seller stated he heard they were stable down to even 1 ohm. The Treo is more than capable of giving the comps rated power @ 2 ohms safely.
Well thanks for a lot of nothing underfire, just a waste of time and money $
If these are the REAL specs,
75x2@4ohm
150x2@2ohm
350x1@4 ohm
If I bridge it at 2 ohms, what should I look for on the DMM?
I just want to listen to bass until I find someone off CL to buy some of this shyt
Read the thread you posted.
"Confirmed that these are 2 ohm stable and will do 600+ @2ohms"
Exactly what I've been telling you. You do not even need that much power ATM, it's more than capable of what you need with the comps.
Others are saying that my amp is a 300 rms amp,
In the thread he said put bigger fuses in it
---------- Post added at 10:28 PM ---------- Previous post was at 10:27 PM ----------
Is there anyway with the DMM I can somehow calculate how much watts or RMS my amp is putting out?
Others are saying that my amp is a 300 rms amp, In the thread he said put bigger fuses in it
It's 350 @ 4, I was trying to get specs off the top of my head, that's why I got it wrong, sorry about that. As you lower the Ohm load (Raise the resistance) the power output will go up, most 2 channels won't go past 4 ohms, but I assure you, the Treo can. You will not need bigger fuses if you set it to 300RMS, you will be drawing about the same amount of power still.
if you wanted to crank it up as far is it could go @ 2 ohms, you may need to because it might be drawing more than 40 amps then.
Calculating output of the amp accurately would require a better DMM and a Clamp meter, a good set-up would run 4-500$.
Others are saying that my amp is a 300 rms amp, In the thread he said put bigger fuses in itf
Regardless of how much power the amp is u need to find 24.49 on dmm thats about all those can handle for long end of story..dont fvck around with putting different fuses in and running amp below its stability..or upgrade if u arent satisfied
Basically I cannot get a straight answer on what my amp is giving out RIGHT now @2ohms and therefor cannot set my gain right, meaning i cannot BASS
It doesnt matter man stop sweating it ..those subs can only handle 150 each
---------- Post added at 11:53 PM ---------- Previous post was at 11:52 PM ----------
U dont need to know how much it puts out ..only what ur subs can handle
darron016
darron016
minneapolis, mn
calebkhill
