Bass dosent wobble
Quick question. Once you set your volume at 80% or use an oscope, your HU wont clip even if you go up on the eq and source level adjusters right?
Dont want to go up on any HU levels if it will clip
And when using an android, wont the phone clip?? I need the signal/volume from my phone to be clean too. Ill google in the meantime.
You want to set the gain on the max settings you will use. If you adjust other settings higher after you set the gain, you will start to clip.
darron016
darron016
minneapolis, mn
calebkhill
