Bass cuts out when turning bass knob up and comes back after turning volume max on head unit
  • 4
Could be an issue with the bass knob itself. The bass knob is a potentiomenter that can have "dead spots" and provide an incorrect signal. Pay attention to how the subs behave at each position of the bass knob.
If i were to guess there is a cold solder joint on the ground of the input stage on your amp. when you turn up the bass knob the vibrations causes it to lose connectivity, when you turn up the volume to max on the hu the preamp has enough current and voltage to arc the connection back to life
Definitely an option, i've seen that before also.
You can just unplug the bass knob and see if you can replicate the problem without it. A bass knob is just an attenuator, it doesn't actually boost the signal.
The first thing you should check is the voltage at the amp when it happens. The vast majority of the time it's a problem with input power
ringer ringer, chicken dinner... its your headunit. gotta upgrade mine as well, does the same thing, it cannot handle the additonal speakers, just...
Yeah I did remove the base cap and just straight wire you know grounded to amp and everything how it originally was before the base cap and it...
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
208
Defiantly. LOL 😂 It has never happened to me👀:poop:
372
Maybe voltage loss? I always set my LFP to 80 and on steeper slope with no noticeable SPL loss. Playing a sine wave is a lot easier on your...
457
Jakefry.888
Jakefry.888
Virginia beach
wew lad
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
