Bass cuts out when turning bass knob up and comes back after turning volume max on head unit
If i were to guess there is a cold solder joint on the ground of the input stage on your amp. when you turn up the bass knob the vibrations causes it to lose connectivity, when you turn up the volume to max on the hu the preamp has enough current and voltage to arc the connection back to life
Definitely an option, i've seen that before also.
You can just unplug the bass knob and see if you can replicate the problem without it. A bass knob is just an attenuator, it doesn't actually boost the signal.
Jakefry.888
CarAudio.com Newbie
Jakefry.888
Virginia beach
wew lad
