Barely started my install and... it starts raining =[
haha put the backseats back up. panel rattle will **** hard core. also see if you could tilt your mirror like that with the back seats up. i can. :p
ah yes and nice install you got there. patience is the key. it may have tekn you months but it turned out really nice.
heh.. thanks. but yeah seats were only down for the vid. seats are back up and gains are way down. i dont think its necessary to drive around that loud //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif but its nice to have a TON of headroom if i ever want more bass
listened to it a little further today.. i am quite disappointed in the sub.. but maybe its cause the box is a bit too small so i'm going to try to stuff some polyfill in there and hope it sounds a little better.. if not im going to swap it out and put my Q in the box and see if i like it more.
i got some polyfill from walmart.. in a big bag how would i go about to stuffing the box? wouldnt the air blow it out the port?
EDIT: The box was meant for the Q but since i got such a good deal on the mag i wanted to try it out..
iirc, the enclosure recommendation is the same for the mag and Q.
what the specs of the box?
its 3.3cuft @ 33hz before displacement... so yeah its smaller then recomended //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
The chassis should/does ultimately ground to the battery. Always. The chassis is not the ground.
Anode to cathode and all that good stuff.
i dont understand all that.. but the battery in the back is grounded to the chassis.
thats a good thing right?
XaznKewLguyX
bloop
XaznKewLguyX
SoCal
XaznKewLguyX
