Bandpass!?
People "hate" because properly made bandpass boxes don't "boom" or "thump" or "pound" or whatever you want to call it. They play smooth, fast, accurate bass, and they play it loud. It's hard to put into words, I've used BP before and it does offer a pretty unique sound.
I only notice "hating" when someone refers to a pre manufactured sub enclosure. A properly designed band pass enclosure, is not as easy as a ported box. And normally is much larger.
how can you tell if a prefab bandpass will work with your subs. For instance, i have 2 alpine swr 12's and am looking at a couple bandpass boxs on ebay, how can i check to see if they will work well with these subs by using the dimensions or whatever they provide? or do u think the swr's would sound better in a diff style of box, sealed or ported?
From diysubwoofers.org:
Low Q (
The driver's efficiency bandwidth product (EBP) should also be taken into account - this is derived from the Fs/Qes.
EBP = Fs / Qes50 or less = Sealed / 4th order Bandpass.
50 - 90 = flexible enclosure options.
90 or greater = Ported / 6th order Bandpass
All that being said, I wouldn't use a prefab enclosure regardless of the sub's parameters //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
how can you tell if a prefab bandpass will work with your subs?
It won't. That's the answer as far as prefab bandpass goes. A properly made basndpass must be specifically tailored to the sub(s) going in it. If it is off even just a bit it will sound bad, won't be as loud and could destroy the sub with minimal power. Bandpass boxes are very much a "one size fits none" type of deal.
Most of the people that say "bandpass ****" have only ever heard the prefab boxes. And based on what they hav heard, they are well justified in what they think. However, a properly designed and well built bandpass enclosure can sound great and be really efficient. As much a +6dB compared to a sealed enclosure. They get loud with less power but typically can't handle as much power either. The cone of the sub is being damped by 2 chambers of air and since the box mask the noises of a speaker in distress, it becomes quite easy to literally rip the voicecoil loose from the cone and not realize it until it is too late.
Hey i have 2 bandpass boxes and they had 2 holes on the top and i covered up one on each so i could mount the amp in the center, (i also bolted them together through the back chamber and didnt mess with the fron) n then i made another hole in the back center of each box about the same size just a little smaller and i was wondering if i messed up anything.
probably.
as said properly build bandpass can be awesome. in some cars they are necessary to get sound into the cabin when the trunk is very well sealed from the cabin(bmw, lexus, etc) in this case, firing through the skihole or a hole in the rear deck in some cars is about the only way to get bass in the vehicle.
4th order bandpass boxes usually aren't overwhelmingly large, however 6th order bandpass boxes tend to get big fast. and then you have transmission lines and folded horns on the top of the 'big box' list //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So how would i build a bandpass or find out the dimensions of the box, and ports and all that needed to properly build one to fit my 2 alpine swr's? are there any sites out there to calculate all that stuff or anything like that to tell you exactly how to build each piece of it to properly work with my swr's?
i'd call alpine tech and see what they recommend for a bandpass. what kind of airspace you'll need in each chamber, how much port area you need, and what it should be tuned to for your type of music. if not, then you'll have to just do some math. you could try winisd it will give you a ballpark, but don't rely on it completly
solidcrowd
solidcrowd
Buffalo, New York
thefunkybunch
