Bandpass- What is it? Is it good?
they have HORRIBLE response. all the notes sound the same, it is loud ...but sound like fart. sealed is the best for SQ! ported, IMO, is the best all around. It is much louder than sealed...u lose some sq, but if tuned low...they still sound good. peace
NG
Originally posted by swingking03 I am going to get a new box for my audiobahn 12's. What are the pros and cons of a bandpass box. Is it better than sealed or ported?
If its a prefab bandpass, its worse then either. I haven't heard a custom bandpass that was actually built to the drivers specs, but a sealed or ported box will outperform any prefab bandpass...
Bandpass boxes are sort of like ported boxes....but there are 2 enclosure for the sub, one in the front, and one in the back. The front one acts like a low pass filter, but unfortunately bandpass also results in a limited frequency response. That's the most basic description of one, but it's much more complex if you actually want to build one, such as 4th order, 6th order, etc.. They are only successful when the box is designed specifically for your subs, and it is built pefectly. Any pre-fab bandpass box will sound pretty bad. If you want your subs to be louder, use ported, if you're going for SQ, use sealed.
Originally posted by Gauntlet Bandpass boxes are sort of like ported boxes....but there are 2 enclosure for the sub, one in the front, and one in the back. The front one acts like a low pass filter, but unfortunately bandpass also results in a limited frequency response. That's the most basic description of one, but it's much more complex if you actually want to build one, such as 4th order, 6th order, etc.. They are only successful when the box is designed specifically for your subs, and it is built pefectly. Any pre-fab bandpass box will sound pretty bad. If you want your subs to be louder, use ported, if you're going for SQ, use sealed.
6th order boxes can end up being huge if its designed right for your subs
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
4
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I hope you didn’t misInterpret my last message.. I was excited that I actually understand what you’re talking about… Lol! I will level with you. I...
14
If you're serious about an 18 in the trunk front firing/trunkwalled go ahead. At least you got electrical covered /w/ a 600rms sub I'd wager. If...
16
3K
swingking03
swingking03
Tampa, FL
ryan_feine
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
