band pass or sealed
  • 2
band pass would produce more bass than sealed if tuned properly...
but DONT put it bandpass:nono: ...save your ears from the trauma //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif....
if you want more bass from your sub, put it ported, it will still lose SQ, but give you more spl. and it's lots better than bandpass. but make sure you tune it to the correct Hz your sub calls for, or will not perform to its standards..
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
972
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
  • Locked
The Orion Concept 97.2 was the worlds first stand alone digital 30 band 2 channel equalizer. The Orion Concept 97.2 processes all the equalization...
You need to re-phrase the question. Are you trying to use active bi-amplification via outboard amplifiers or do you just want the recommended...
.Run HU at full pass, cross HP filter on the amp at 40-50Hz - or - Cross the HU at 40-50Hz and amp at full pass. I prefer to adjust prior to the amp
drew
drew
mo
more_spl
    May 18, 2024
    May 16, 2024
