Bad Squealing From Kenwood X794
ctmaudi
Akron, OH
The other night I noticed a bad squealing from my HU when the volume is down or off. I can drown it out by turning it up really loud though.
Came out of no where, and never did it before. The higher I rev the car the louder it gets. Now, sometimes it does it and sometimes it doesnt. It seems that if I play music with it turned up loud enough it stops after a couple minutes, but that might be a coincidence.
Ive had it for months without issue.
I know this is old, but I never got a chance to work on it till now.
Firstly, I started getting a bad crackling a couple weeks ago through the tweeters, then in the past couple days it would just shut off by itself, then come back on.
Found the cause for that, my power wire from the alt to the battery fell out of the terminal, and was melted up against the heat sheild, sparking. Luckily it never caught fire.
So I removed that, I tried grounding the RCAs on the HU, I tried running a 4awg wire from the HU ground to the battery, and I even tried another HU. Nothing fixed the whine.
It does it 9/10 I start the car, but there are still random times that it doesnt do it. If I just turn the car electriconics on without starting, it doesnt do it, only when the engine is running.
It seems like it started doing it once its starting getting warm out. It almost seems as if the hotter it is, the louder is it, but it could just be getting worse over time and just a coinicidence.
I made a quick vid.
http://s864.photobucket.com/albums/ab207/ctmaudi/?action=view&current=video-2011-07-26-20-12-49.mp4
That's why I said it really depends on the sub 😂
16
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
ctmaudi
ctmaudi
Akron, OH
ctmaudi
