bad rear speaker channels HELP
954runner
just bumpin my music
I have a JBL GTO 755.6II amp, with the sub channels bridged, and originally I was just running my speakers off the front channels of the amp.
However, the speakers were not loud enough for my liking, so I decided to bridge them with the back channels. I bought a 4 channel RCA from knukonceptz and ran it from the headunit to the back of my car. Unfortunately, the RCA's were about 2 feet short, and so I was stuck without sound until my RCA extensions came in the mail today.
I put them in, hooked up the speaker wires to the correct input, and fired up my car. The only problem is, the RIGHT speaker doesn't play anything unless I turn up the volume to the max. My gains are set at 60/80, but I have to turn it up to 80/80 to get anything out of the right speaker. When I turn it down, the right channel shuts off.
So, I know that the rear channels DO play music, but the connection isn't very good. I tested all the other rear speaker input combinations and they are all gave me the same outcome.
Is there a way to fix this problem? Is it a difficult or easy fix? Or should I look into a new amp? Or revert to my old settings (run speakers off FRONT channels)?
Thanks for the help
It sounds like you have an RCA grounding out. If you wired your HU wrong for that speaker you could very well be getting a crossed signal in your RCA connection. Verify your speaker AND the HU is wired correctly for + and -.
when bridging, you don't need the rear RCAs and you have to re-wire the speakers outputs right??? there's markings on the speaker outputs for connecting bridged and i'm pretty sure it just uses the front RCA connections.
I'll try only hooking up the front RCA's... I thought I already did that but I'll double check just to be sure.
And yes, I rewired the speaker wires to exactly what the amp manual specified.
You need to have a input signal going to all the channels on your amplifier if you want to bridge it. How will the rear channel produce sound if there is no input signal going to that part of the amp.
DOH, i just woke up and came in here to tell him to try the left front and left rear inputs!!!
http://manuals.harman.com/JBL/CAR/Owner%27s%20Manual/GTOAmpIIOM_web_rev_12_14_04.pdf
According to page 5 and page 8, If you did this wrong, then you fried the amp. Quick Question...... Did you change the channel select switch on the amp? It should have one that says 3, 4, 5, 6 channel mode. You would want 3 channel mode. and also, The $ you spent buying that 4channel RCA was not necessary. Most amps can run only one set of RCAs. Like my soundstream 4 channel. I can use all for channels with only L R in, not rear in. Try checking the amps output mode...
I'm drunk so i'll try to explain my best
I found out the problem tonight.
I turned on the radio tonight and it was playing fine. I played a cd and it was fine but when i played my ipod it wasnt.
So, it turns out its my cable that connect my ipod to my headunit.
I'm gonna hae to go back tnad fix that tomorrow r something woo!
Then whats the point of having the rear inputs....lol
954runner
954runner
Dallas, TX
Mass Car Audio
vegang
vegang
