Bad luck with my love for bass. Any help please?
The gain is about halfway between 0 and max. There could be a poor connection but I'm not sure where it would be. I just had the remote connection fixed up today.
bring the gain down just a tad, and yes when you have time take a look down where your wires run and look for a pinch or stripped wire, both the power and ground, you said you fixed the remote wire so I guess don't worry about that, if it was a bad ground there would likely be dimming lights
Okay I'll check for a pinched wire tomorrow morning and bring down the gain slightly. If I don't find anything then I'll just head back to the shop tomorrow and see what they can do. I want my bass! Thanks for the help!
So since spring break has begun, I decided to finally figure why my amp stopped working about 5 months ago. After a few days of messing around with it and getting nowhere, I decided yesterday to go to a shop to figure out the problem. My amp fried and I needed a new one. They installed a new one and on my way home I enjoyed the bass that I'd missed for so long. Then it stopped working as soon as I pulled in my driveway. No big deal, I thought. I went back to the shop today to figure out the speaker wires behind my head unit came loose. For about ten minutes I was in bass heaven; then it stopped again. This time, the red status light started coming on whenever my volume went above 15. The bass would play up until I passed that point. Now at home again, I'm trying to figure out what's wrong and why god doesn't want me to bump down the streets. Maybe it's because I've used my system to force people to speed up in the past. Anyway, the rca's are fine since it's playing at low volumes. The amp is being input almost 14 volts, so it isn't an issue there. On the powerbass site it says the status light comes on when its overheated, nor getting enough volts, or something else I forget. Any ideas what the problem could be before I go back to the shop again tomorrow?
Note: when the status light comes on after vomune 15 the amp stops powering the subs, but is if e from volume 15 and below (not normal listening volume)
what? do explain
lol 6 gauge isn't a problem, I used 8 gauge on the 400watt rms amp I used to own at 2 ohms and I was fine. I have upgraded to 4gauge for my current 1kw setup though.
I agree, you probably have a 2ohm stable amp, but your sub is probably wired to 1ohm
I got some kit from Walmart over the last summer. 6 gauge power wire and same with the ground I'm pretty sure. Then the remote wire and speaker wires I have no clue. I have a feeling I don't know what you mean exactly, sorry. I'm kind of a noob at this.
EDIT: After going back outside, I saw that it actually says 2ohm stable on the side of my amp, not 1ohm. It's pretty cold out so I kind of quickly skimmed the sides and went back inside.
That's most likely your problem. You're wired too low for the amp to handle. You need to either wire those subs to 4 ohm or get different subs. That's if you are wired to 1 ohm right now. Have you measured those subs to see what you are sitting at?
what? do explain
People who drive slow are also typically people who aren't fond of having bass blasted loudly behind them. So if you feel like the guy in front of you should be going a bit faster, just crank up the system and bump them to an appropriate speed.
oh yeah i figured, much safer/better than tailgating
1 of 3 thoughts.
1. Your impedance load is to low for your amp.
2. You have a short. Check the speaker wires going from the amp to the sub box. And check the wires going from inside the box to the subs.
3. Amp is toast.
Try a different amp if you can find one to try. For speaker wires the way they are connected together there could be a short you can't see. I'd try a new run of speaker wire just to rule it out. From the amp to the box and the box to the sub.
Check your ground as well.
TheInocence
TheInocence
Elkton, MD
Better-Action
