Bad idea?
FKNkid
Hi everyone so i have a colorado crew and i want to put 2 subs ( either 8'' treo ssi or 10'' re sl series) in the back under my seats. i really want a ported box, the problem is the recommended ported enclosure is .75 cu ft for the treo and .65 for the re.
Question 1- do you think using the sealed box specs to make a ported box is a bad idea?
Question 2 - i do have only about 5 inches in height to work with and the treo mounting depth is 4.3somthing, so will this also cause any problems? because the sub is so close to the bottom.
sorry if its hard to understand i dont really know what im talking about and aint good at grammer //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
you probably need about 3 in. of clearance between the magnet and the wall of the box
would it sound like sh*t if i were to make the ported box to the sealed specs? even though its tuned to the right hz's
drag says NO to question 2 but hoxie you say its ok??
yeah with my personal experience. I had a (10" of each) fi x, jl w0, American bass dx, re 10, and 2 10" kicker l5's. The kickers were in a box i built, but definitely not more than a 1/4" of space between magnet and box, never had a problem with them and i ran them both pretttty hard.
These were in a little truck box, i had to make a 1/2" spacer for the fi x... meaning i had less than a 1/2" of space. American bass was also BARELY in there, i'd estimate no more than 1/8th inch of spacing.... no problems... so, yes, in my experience its never been a problem"
thanks thats really good to hear. so why dont you think i should use the sealed box vol. for a ported one?
thankyou hoxie for your help
Aloha
Well, to be honest i've never heard it, but I can imagine it wouldnt really be able to be tuned correctly at all. Plus I would think that the manufacturers would have tried it during testing and it probably doesnt sound good...
if that 5" is before the box, remember that you need to subtract 1.5inches total for the thickness of the top/bottom of the box
x2
And as for the mounting depth-- just think... the hole on the bottom of your magnet [if your sub is built that way] is bringing in air-- thus if you make it too close it won't have enough space to **** in air... now, if it's just a magnet and no 'pole hole', plop that sucker right up against it. But odds are it will be.
ya thanks i did that? add 1.5 right not subtract? anyways ya i get what you mean
FKNkid
FKNkid
HAWAII
FKNkid
Mike Mccabe
