BAD GAS! Will this flow n go **** it out of the tank?
many newer cars have valves in the filler neck that prevent gas from flowing back if the vehicle rolls over. I know I tried to drain the gas in my montero by siphoning and it didn't work, the valve prevents you from getting a tube down there.
Our 2000 Taurus also has one of these.
I* didnt know if it had to be sealed or anything like that, or if the hose would snake down into the tank or if there was some sort of blockage to prevent this sort of stuff
actually, depending on the year, they do have check balls in there to prevent fuel coming back out...
for some reason they are disregarding suggestions like these:confused:
they are disregarding the alcohol posts because alcohol likes to eat fuel filters. and that sucks *** when you have a fuel filter that is integral in a fuel sender unit.
itll turn a cheap fix into what could be a very expensive one
Definetely not dropping the tank, it involves a lot of interior stripping and definetely not a 40 minute job, just wanna know if this flow n go I already purchased will work
ON AN S10!?! Tank will virtually fall out if you let it! Its under the bed, not the cab.. Wheres the interior work come from?
WOT
Banned
WOT
Toronto,CANADA
IgnoreMe
