B&C PBZ 40 15" for open-baffle midbass use?
thadman
Im looking for the lowest distortion midbass in an open baffle enclosure
Ive found a great deal on a pair of B&C PBZ 40 15" drivers and was wondering if they'd perform with low distortion (similar to Dayton Reference series) from 50-300 or so hz on a 24" baffle. The 8NDL51 (sp?) seems to be pretty highly regarded amongst this forum. Im crossing them off to an Ava 18" in a sonotube 18 on the low-end and a pair of Seas Excel W18Es on the topend.
Here are the thiele small parameters for the driver. Its got an 8mm xmax (pretty high for a PA driver), Qts .29 (I realize Ill have to do some equalization), Fs of 39hz, 97dB sensitivity, and a 2.4mH inductance (is this too high?)
Have you gone to DIYAudio and asked this question? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'd be more concerned about the Excel W18's on top...as they have a nasty breakup node when run too high, you're better off with planars (BG Neo 8's come to mind) in an OB like this.
Yes, the question is on multiple forums (diyma, diyaudio, and here)
The W18E will be crossed off around 1.5khz, so I wont have the opportunity to excite that nasty third harmonic:D
I dont think the BG Neo8 would transition very well to a PA 15" like this (400-600hz xover). Am I wrong? I'd love to use a pair, but I dont think they'd handle the low xover very well.
The Fs and Qts looks a little low and the inductance seems pretty high, but theyve got double the xmax of most PA drivers and crazy sensitivity. I've also found a pretty good deal on them. Will these play with authority and low distortion in their intended passband as midbass drivers?
thadman
thadman
Indiana
thadman
