Avalanche Vs. Magnum Pics
I wonder if the inductance is due to xbl^2 or if that is just a coincidence. Ehh, your only going to get so much top end (compartively speaking) out of a driver with 30mm xmax. Not really the point I guess.
XBL^2 in and of itself doesn't cut off the top end, but it does help alot with bottom end as the driver can continue to move forward with the same amount of BL for longer stroke. Going from 60 Hz to 30 Hz requires 400% more x-max, so it only makes sense //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I think what happens is that many XBL^2 designs use coils with a ton of layers to "make up for" being short so they can soak up power, this would lead to a higher inductance and thus less top end. With the same number of layers XBL^2 will have much lower inductance than overhung at a given x-max rating due to the shorter coil.
Anyhow... I liked my Brahma and I like my Mags //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif They are two totally different speakers but I like both of them.
umm... the mag was louder on the higher notes, where the avas where louder on the lower notes. Sooo as alot of people know higher notes register higher usually on a mic so i would say the mag was the loudest in that aspect. But like i said before i liked the avas better overall.
Did you compare one ava to one mag or have you always ran both avas?
And to get more coil in the gap; XBL^2 needs as much flux utilization as it can get to increase efficiency.
baseballfan698
baseballfan698
Indiana
negative3five
michigan born
    May 14, 2026
michigan born
    May 14, 2026
