Autotek, Massive, or Sundown
massive audio amps are great amps and worth every penny its the user that doesn't use them right and abuse them so there eventually gonna break down. i have the p1500 for about a year now and might grab the massive p3000 next or just strap 2 p1500s.
Either way, all the p3000 is are two 1500s in one chassis anyway. Its cheaper for you to get one more 1500.
Autotek Mean Machines are the way to go. Stay away from their lower lines. That goes for all manufactures by the way.
I never heard of Autotek at Walmart. But I never shop at Walmart. Especially for audio! If that happens to be true ( i doudt it), I have a strong suspiscion that its their street machine lines. You wont see the Mean MAchines in Walmart.
I've owned 2 Massive p3000.1's and an Autotek MM3000.1. I'd take the Autotek over the Massive anyday. One of the Massives were bad out of the box and I ended up having to pay for a whole new board. The biggest shit is it wasn't even my fault becuase I hooked the other one up the exact same way, and it worked. Massive then claims that it was due to low voltage. The Massive will blow under 2 ohm loads. I'll never buy Massive again unless it was flea market priced. The Autotek was a beast though. Never went into protect, never given me any problems and said to be .5 ohm stable. I still miss that amp to this day. Major regrets selling it, not to mention it was the best amp I have ever owned, and I've had quite a bit. The Sundown, i can't speak for but everyone praises the CS and Jacob is a good guy. I've bought from him before with no problems. I think there are tests somewhere with the SD 3kD doing rated power at 10.xx volts:).
nda03vic
nda03vic
Richmond, Va
headbussaboi
