Audioque AQ3500.1D
Budget_Ballin'
TEAM DC
Audioque AQ3500.1D with bass cord and knob.
Cosmetically 8.5-9/10 very few scratches on the sides and feet from mounting. Bottom is scuffed a little. Nothing too major at all. Overall in great shape.
Mechanically 10/10 works like a champ, just need more power
The AQ3500.1 is fully stable down to one ohm.
Daisy Chain connection of two AQ3500.1 stable down to two ohms
Four way protection circuits: Speaker shorts, DC offset, High/Low voltage, Thermal protection
High current MOSFET switching devices
24db/oct slope crossovers, Fully adjustable Low Pass Filter and Subsonic Filter
Remote Gain Knob Included
Specifications
Model AQ3500D.1
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2V ~ 5V
Variable Low Pass Filter 20Hz ~ 200Hz @ 24dB/Slope
Subsonic Filter 10Hz ~ 50Hz @ 24dB/Slope
2 amp linkable connection Output Master / Input Slave
Clipping Display Led On Remote Gain Control
Signal to Noise Ratio 85dB
Damping Factor 250
Efficiency 85% at 4 ohm
External Fuse Rating 380 Amp in-line, 760 for pair
Tested Voltage 14.4V
Working Voltage 9.5V ~ 18.5V**
4 ohm power @ 12V @ 1% THD 750W x 1
4 ohm power @ 14.4V @ 1% THD 1400W x 1
2 ohm power @ 14.4V @ 1% THD 2600W x 1
1 ohm power @ 14.4V @
1 ohm Power @ 16V** @ 1% THD 5300W x 1
1 ohm Power @ 18V** @ 1% THD 6000W x 1
1 ohm Power @ 18V** @ 10% THD 7500W x 1
2 ohm Linked Power @ 14.4V @ 1% THD 8600W x 1
2 ohm Linked Power @ 16V** @ 1% THD 10600W x 1
2 ohm Linked Power @ 18V** @ 1% THD 12000W x 1
2 ohm Linked Power @ 18V** @ 10% THD 15000W x 1
Dimensions (mm) 657.2mm (L) x 241.3mm (W) x 66.7mm (H)
Dimensions (in) 25.875in (L) x 9.5in (W) x 2.625in (H)
Power and Ground Inputs 0 Guage x 2
$650/shipped.
NO TRADES
Will be shipped ups upon payment. Insured. Packed super duper well in the original box and probably another one or two!
This amp hasn't seen below 13 volts. It's been ran off of a mechman 270a alt and 3 xs d3400s.
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). View attachment 26537134View attachment 26537135View attachment 26537136View attachment 26537137
help me make up my mind guys. should i go with a dd m4 or a cendo 5500? i have 2 aq hdc4 18s right now running at 1 ohm and im looking for more power than this to get them movin. i have 3 xs d3400s and a mechman 270a alt. im not really looking to by more batts or another alt right now. if i had to do anything electrical it would be buying another batt, max. what would be the best amp to get?
should just get the m4a, just get an extra battery and call it a day. pwk designs (cant rem his name) has only 1 battcap 4000 and a battcap3000 up front on a single alt and runs its with almost no volt. drop. there really effic. amp as long as you dont let it drop below like 11.5v your golden...
Keep in mind those batcaps are the best batteries in the business right now. Those 4k's cost like 600 new
Damm are they that high??? Jeez, they are proud of those huh
They're worth it. I've been using the batcap 2k as a starter batt and it's like half the size that my battery holder can fit. Voltage is way better than when I had a stock battery in there and it doesn't have a problem starting up my suv when it's below zero out. They may be pricey but they're worth every penny imo
Are there any comparables out there to these? I mean obviously there is nothing thats hte exact same, but my local sams club has 55ah Duracell AGM batteries for 79 bucks a piece. I was thinking 1 under the hood and 2 in the trunk, thats 3 batteries totaling 165 ah for about 240 bucks. Do you think these will be decent batteriis?? The east penn battery company makes them. Same makers of the "Deka" batteries and a few others as well.. Not going the cheap route, but i just spent 315 on a 320a alt from tenney alts and now i need a few batts for a reasonable price. Duracell AGM batts at Sams club
The only batteries I would buy from a store are Diehard Platinum batteries from sears. The P-2 battery (group 34 iirc) costs like $220 picked up and it has some nice specs. Keep in mind AH isn't everything, there's a lot more that goes into a battery than just its AH spec.
Budget_Ballin'
TEAM DC
Budget_Ballin'
Southern Ohio, United States
Budget_Ballin'
Mike Mccabe
