Audioque AQ3500.1D
Budget_Ballin'
TEAM DC
Audioque AQ3500.1D with bass cord and knob.
Cosmetically 8.5-9/10 very few scratches on the sides and feet from mounting. Bottom is scuffed a little. Nothing too major at all. Overall in great shape.
Mechanically 10/10 works like a champ, just need more power
The AQ3500.1 is fully stable down to one ohm.
Daisy Chain connection of two AQ3500.1 stable down to two ohms
Four way protection circuits: Speaker shorts, DC offset, High/Low voltage, Thermal protection
High current MOSFET switching devices
24db/oct slope crossovers, Fully adjustable Low Pass Filter and Subsonic Filter
Remote Gain Knob Included
Specifications
Model AQ3500D.1
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2V ~ 5V
Variable Low Pass Filter 20Hz ~ 200Hz @ 24dB/Slope
Subsonic Filter 10Hz ~ 50Hz @ 24dB/Slope
2 amp linkable connection Output Master / Input Slave
Clipping Display Led On Remote Gain Control
Signal to Noise Ratio 85dB
Damping Factor 250
Efficiency 85% at 4 ohm
External Fuse Rating 380 Amp in-line, 760 for pair
Tested Voltage 14.4V
Working Voltage 9.5V ~ 18.5V**
4 ohm power @ 12V @ 1% THD 750W x 1
4 ohm power @ 14.4V @ 1% THD 1400W x 1
2 ohm power @ 14.4V @ 1% THD 2600W x 1
1 ohm power @ 14.4V @
1 ohm Power @ 16V** @ 1% THD 5300W x 1
1 ohm Power @ 18V** @ 1% THD 6000W x 1
1 ohm Power @ 18V** @ 10% THD 7500W x 1
2 ohm Linked Power @ 14.4V @ 1% THD 8600W x 1
2 ohm Linked Power @ 16V** @ 1% THD 10600W x 1
2 ohm Linked Power @ 18V** @ 1% THD 12000W x 1
2 ohm Linked Power @ 18V** @ 10% THD 15000W x 1
Dimensions (mm) 657.2mm (L) x 241.3mm (W) x 66.7mm (H)
Dimensions (in) 25.875in (L) x 9.5in (W) x 2.625in (H)
Power and Ground Inputs 0 Guage x 2
$650/shipped.
NO TRADES
Will be shipped ups upon payment. Insured. Packed super duper well in the original box and probably another one or two!
This amp hasn't seen below 13 volts. It's been ran off of a mechman 270a alt and 3 xs d3400s.
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). View attachment 26537134View attachment 26537135View attachment 26537136View attachment 26537137
Budget_Ballin'
TEAM DC
Budget_Ballin'
Southern Ohio, United States
Budget_Ballin'
