FS: Alpine PXE-H650 Imprint OEM Integration Processor
groundpound4200
Da fuq did I just read?
Alpine PXE-H650 Imprint Processor
Used. The face has a few scratches on the metal surface, nothing really on the green screen. This includes:
-processor
-new power/ ground harness
-new remote
-new line in harness
-new wired remote sensor
-Imprint microphone
-Burnt copy of setup disc. Alpine burned me a copy when I called them lol.
This unit will also allow you to add imprint to an aftermarket HU as it has high level and low level inputs. Fully active capable. Auto time correction, EQ, all kinds of goodies. I believe you can even hook it up to your laptop with a USB cord.
If you're adding amplifiers to a factory system and want the best possible sound, put the PXE-H650 System Integration Sound Processor into your system. It takes the output of your factory radio, cleans it up, and applies special IMPRINT sound-shaping technology so your amps get a clean signal. You'll build a great-sounding system while keeping the look and functionality of your factory radio's dashboard setup, steering wheel controls, and factory extras.
A 512-band equalizer removes the preset EQ curve from your factory radio's output, sending a clean "flat" signal to your amplifiers through four sets of preamp outputs. High- and low-pass filters for each output channel route the right frequencies to each amp.
IMPRINT sound tuning technology
The PXE-H650 takes the guesswork out of system setup with the impressive automatic sound tuning feature. Connect the included microphone and place it in your preferred listening position in the vehicle. IMPRINT will analyze the acoustics in each listening postion, adjusting the sound so that any seat in the car can be the best seat in the house.
You can use either the PXE-H650's controls or a PC loaded with the supplied software for easy system setup and adjustment. Like to tweak it yourself? No problem — you'll find a built-in 3-band parametric equalizer, manual crossover controls, and manual time-correction controls built in as well.
system integration sound processor for use when adding amps to a factory system
four sets of preamp outputs (front 1, front 2, rear, and subwoofer)
IMPRINT sound technology with a 512-band EQ and time correction
manually adjustable 3-band parametric EQ
high- and low-pass filters
included microphone allows custom sound shaping for your vehicle
Price: $150 shipped in the US
USPS or Fedex
do you loose your volume control on your deck even if you use an alpine head unit?
No, I leave the processor turned all the way up and use my main volume knob on my factory deck. This processor can go to max volume and not clip as long as you set it up right and turn the master volume to an unclipped level.
This is sold BTW
groundpound4200
groundpound4200
Mankato, MN
groundpound4200
vegang
vegang
