Audiopipe APCL-15001D on SMD Amp Dyno at 0.5 ohms Dynamic RMS
And what is music but a series of short bursts? The dynamic burst test on the AD-1 is the closest simulation to music one can get on resistive load and music happens to be what 99%+ audio amplifiers are used for. Peak ratings, on the other hand, are merely expressions of power in a square wave and thus, are indeed meaningless.
Not to mention, this is the same dynamic burst test that any other amplifier can be subjected to so even though it isn't some exact replication of a music track, it is an accurate and repeatable method of testing more than one amplifier's performance in an "all other things being equal" environment... which is requisite of any test which seeks scientific accuracy.
Still don't see what your getting at .. This isn't a long enough period to be a burp or music we are talking milla second burst .. And on top of that they were saying the dc 5k was doing 8k+ on this test .. Your not seeing that in your car either lol .. Bottom line this test is worthless lets see the 1 ohm certified runs if were gunna use that crap .. Or clamp it on music with subs in the car .. Will be nothing close to this inflated peak power bs
My point is the uninformed consumer is going to see this test, see what a "deal" this amp is, take it home, set their gains to that point, and fry their equipment. All because some video online told them they can do it. I see the test as moot and misleading.
The test track is ten seconds of bursts, not a millisecond of burst.
So you're arguing that uninformed people wouldn't (or don't already) otherwise buy these amps, take them home and then damage their equipment?
The video doesn't tell anyone they can do anything. It's a bench test of an audio amplifier.
Yes, this test was done on a machine, not in a car. What's the difference? I was using a big power supply instead of an alternator and batteries...that's it!
The Amp Dyno uses resistive loads and those of you who are "clamping" your amps to get the power are actually getting VA or Volt Amps, not Watts if you are using speakers instead of resistors. It's electrical engineering, but a pretty simple explanation. Reactive loads (speakers) have electrical phasing which has to be taken into account in order to obtain the power factor and Wattage measurement. It's not as simple as you think to obtain wattage measurements with using speakers, but using resistors, yes it is (along with a THD/clipping meter). The AD-1 was designed by the head engineer at RF for over 10yrs and the designer of the impressive T15kW. I test all of my amps now using the AD-1 and it's a consistent way to get results, and yes, they are accurate.
I specifically put the extra text in the video explaining the dynamic RMS power mode, but doubt most people will watch and read it. Some will just shake their heads and say "NO Way" and go back to keyboard commando mode. I'm just an audio enthusiast who likes to test amps. I didn't really care how this amp did on the Dyno, but it's fun when an amp goes beyond my expectations.
Back to the explanations on why this test wasn't valid, just wanted to break for some facts...
I actually read through the test, surprise surprise! That's why I actually admitted I was wrong in calling it a fake result on Facebook, because it is so unbelievable. I do really want to see certified test runs, though.
this amp in question requires a 100A fuse. With some simple math, we can figure out what it may put out RMS-wise at 1ohm
14.4v x 100a = 1440watts
1440watts - 30% inefficiency for typical D-class amps = 1008watts rms
worst case scenario........1440watts - 40% = 864watts
finding the median......1008 + 864 = 1872/2 = 936wrms
The audiopipe apcl1500 can do around 936wrms at 1ohm.
Post up the certified one ohm run....
this amp in question requires a 100A fuse. With some simple math' date=' we can figure out what it may put out RMS-wise at 1ohm
The audiopipe apcl1500 can do around 936wrms at 1ohm.[/quote']
Not saying you are wrong... But fuse rating doesn't always mean how much power something will put out. Theoretically, yes.... But IRL no.,
you can get pretty close. This is assuming your car has a perfect electrical system.
If you do the math and you get 2000wrms for Amp-X and it actually does 2200wrms, does that 200watt difference matter? Nope......
936wrms to 1000wrms, the fuse ratings don't lie.
If you do the math and you get 2000wrms for Amp-X and it actually does 2200wrms' date=' does that 200watt difference matter? Nope......[/quote']
Every watt matters, I'm poor lol. I get what you are saying though
another example sundown SAZ3500
SAZ-3500D V.2
efficiency at 4ohm is 86%
fuse is 350A for 1ohm, divide by 2 and it's 175A for 2ohms, divide by 2 and it's 87.5A for 4ohms
14.4v x 87.5A = 1260watts
1260watts - 14% inefficiency = 1083.6wrms
The sundown saz3500 is rated 1000wrms at 4 ohms.
You can get VERY close if you have a fuse rating and some efficiency standard.
This APCL-15001D put out 1314W @ 1% THD at 14V (@ 1 ohm) for a few seconds then popped the 100A fuse. Sorry to keep you guys waiting, but it's gonna take me a few days to get the full video edited. I have a day job and it's not editing and posting videos for my YT channel
bigdwiz
Old School Rulz!
bigdwiz
NC
Mass Car Audio
